Highlighted
Roaming
Hi, I am Donghan Shin. I have a question. I’m in Italy now for travel. But I did not text to 150. How can I roaming in Italy now?
Highlighted
by Ace Contributor
Re: Roaming
Hi @Donghan
Can you try this...
If you log into MyEE and go to Manage device, make sure you have activated roaming and international calls.
Or If you have the MyEE app, go to usage controls, activate use phone abroad and make international and premium calls
If that doesn't work, try a manual network search.
Let us know how it goes!
Recent solutions
