by Oludan
New Member
Roaming
Going to Cyprus how do I get up and running with day to day data services.
Solution
Re: Roaming
Hello there @Oludan
You can use your minutes, texts and up to 15GB of data 🙂
Before you go make sure you are set up to use your phone in Cyprus.
You can do this by texting ROAMING to 150, or you can log into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
Have a great time.
Leanne 🙂
Re: Roaming
@Oludan   text roaming to 150 before you leave the UK and you’ll be all set.  You can do this now.  You can use your allowances whilst in Cyprus but be warned if you’re going to Northern Cyprus you may pick up a Turkish cellular network and if that happens you’ll be charged for roaming.
Solution
Re: Roaming
Hello there @Oludan
Have a great time.
Leanne 🙂
