by Psuk99
Roaming
Very confused.  I'm in Thailand, fortunately with free wifi readily available.
However EE texted me the details to buy a travel Pass for 500mb for £6.   Then they text me offering a Roaming plan of 50mb for £5 (higher plans available).
Am I missing something? Why would the travel pass not be the best option?
Re: Roaming
Re: Roaming
Hi @Psuk99
According to the EE roaming costs for Thailand, the daily 500mb is the option open to you.
I would also be careful about using free WiFi without a VPN and wouldn't use it to access anything private, banking apps, email etc.
Re: Roaming
Hi there @Psuk99
Thanks for coming here 🙂
We will text you with the available add-ons for Thailand depending on how much data you will need.
The Travel Data Pass is for 24 hours and will only charge you for the days data is used.
Have a great time 🙂
by Psuk99
Re: Roaming
Leanne_T
My confusion was the multiple texts from EE. One stream from "EE" and another from "1024 from EE". They were separately promoting (for outside EU):
  • Travel Pass for 500mb for £6
  • Roaming plan of 50mb for £5 (higher plans available)
Ther travel pass is the simplest to use and offers the best value.  Under what circumstances would a Roaming plan be beneficial to anyone?  The various EE webpages are not helpful!
Paul
Re: Roaming
Hi @Psuk99
Thanks for coming back to me.
Our texts will show you options available for the country you are visiting 🙂
You can select what best suits your data needs.
