by koocoker
Roaming
I am in Dubia I have a charge of over 40 pounds on my phone despite the fact that I have not used the phone and turned off the data and even purchased an add on for 20 pounds in case I needed to make calls
by Ace Contributor
Re: Roaming
HI @koocoker
Is your voicemail on?
by koocoker
Re: Roaming
No idea I dont use voicemail on my phone
Re: Roaming
What does your bill say as anything outside your tariff will be itemised.
Also turning data off doesn't disable data, apps and the phone will still connect but only briefly.
EE Employee
Re: Roaming
Hi @koocoker and welcome to the community.
Have you received any calls?
Have you dialed any non UK numbers?
@Northerner  if customer is using EE customer would not be charged for data as they would be prompted to purchase bundle.
Many thanks,
Lee
