by Skilled Contributor
Skilled Contributor
Roaming speed?
Morning all
I am on an EE Max plan with 100GB and am going to Tenerife on holiday in 9 days..... any ideas what speeds will be like roaming?
I know Three used to cap speeds and was almost unusable, some people say this is better now and Vodafone offer unrestricted speeds but never used EE when roaming?
Cheers
by Ace Contributor
Re: Roaming speed?
In theory, roaming on Max plans are uncapped.
W
Re: Roaming speed?
@mobilemandan  You should get the fastest speed that the network there allows. As @winston says there is not cap but it will come down to the roaming network speed and what that allows.
