by MatiSh89 Investigator
Roaming problem
Hiya.
I'm in 4GEE Business Plan.
I'm in Poland and I've got a problem.
I can make calls on polish numbers but I can't call back to UK. I'm sure I've got a roaming and I can use my allowance during the trip in UE and in non-UE countries.
Could You help me with that please?
Cheers
12 REPLIES 12
Re: Roaming problem
Hi @MatiSh89
Thank you for posting in community 🙂
What kind of phone are you using?
Is it an iPhone?
Richard
Re: Roaming problem
Yes, I'm using an iPhone 7 Richard.
Re: Roaming problem
Can you attempt the following for me please @MatiSh89
Please tap Settings>>Phone>>Dial Assist
Please ensure Dial Assist is selected.
 If it isn't, please then toggle this on.
Please then try and make your call to the UK for me please.
If it hasn't worked then turn the phone off again and try making the call, ensuring Dial Assist is on.
Richard
Re: Roaming problem
Dial assist is turned on. As well I've rebooted my phone couple of times and still it's not working.
Re: Roaming problem
You can maybe try a manual network selection @MatiSh89 and see if that helps
It could well be the case that roaming is not activated on your line and that an international bar could be on the line.
To rule that out/resolve this, then you will need to please use an alternative landline or mobile to please call business customer services and they will look into this for you.
Thank you
Richard
Re: Roaming problem
To be honest, I'm abroad now And I don't have any other landline.
Is it possible to check this online somehow?
Thanks.
Re: Roaming problem
The only way to check is to speak to customer services I'm afraid @MariSh89
Richard
by Brilliant Contributor
Re: Roaming problem
@MatiSh89 On a buisness plan you can activate roaming yourself just log into my EE then manage my device and it will be in there
Re: Roaming problem
Re: Roaming problem
The 4th option is turned off and when I'm trying to click allow I've got this information:
'Sorry something went wrong.
We've not been able to update the Usage Controls.
Please try again later.'
Re: Roaming problem
It's under this category 'Roaming Abroad'
EE Employee
Re: Roaming problem
Good Morning @MatiSh89
Unfortunately if it's not allowing you to change the Call Abroad option in your My EE you'll need to speak to Business Customer Services.
Thanks - Karen. Smiley Happy
