by Ace Contributor
Roaming problem
Posted in public from a private message I was sent.
@kezkez23 wrote:
Hi Ben
I'm really hoping you can help with a roaming issue I have? I am in Norway at the moment, and before I left the UK I activated Europass, however upon arriving in Norway I have been unable to obtain signal or manually connect to any network. After searching online I notice that I probably do not have roamong enabled against my pay monthly account, and in order to do this I need to contact 150, however I am unable to do this from abroad as it will not connect. Is there anything you can do to help me with this urgent matter please?
Kind regards
Kes
6 REPLIES 6
by Ace Contributor
Re: Roaming problem
Hi @Karen_C could you help at all please.
EE Employee
Re: Roaming problem
Cheers @Ben090
Hi @kezkez23
Just need to ask one quick question, are you a personal EE customer?
Thanks - Karen. Smiley Happy
by kezkez23
Re: Roaming problem
Hi Karen,
Yes I am a personal EE customer on a pay monthly tariff, I hope this helps?
Kind Regards
Kes
EE Employee
Re: Roaming problem
Thanks for getting back to me @kezkez23
It does, thank you!
I'll send you a Private Message with a link to the Chat Team.
They'll be able to help get you up and running.
Have a fab time in Norway!
by kezkez23
Re: Roaming problem
Thanks Karen! Smiley Happy
Kes
EE Employee
Re: Roaming problem
