Highlighted
by Investigator
Roaming not working?
I'm with ee bill pay, but I have moved back to Ireland,
It will not connect to any network for calls, texts and data?
I've tried automatic connect and manual connect and both won't work?
It shows up the different networks on manual connect, but won't connect?
I would really appreciate your help
Gavin
Highlighted
Re: Roaming not working?
Try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Highlighted
by Ace Contributor
Hi @93gavinmoran93
Have you only just moved to Ireland? There is a limit to how long you can roam for in the EU due to the stable links policy.
Can you check roaming is enabled in your account?
If you log into MyEE and go to Manage device, make sure you have activated roaming and international calls.
Or If you have the MyEE app, go to usage controls, activate use phone abroad and make international and premium calls
Highlighted
Hi and welcome to the community, @93gavinmoran93
If you've managed to get connected following @XRaySpeX and @chistery's advice, brilliant!
If not, please try manually selecting a different network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you're getting on.
Highlighted
New Member
HI I’m currently in Tenerife. Ever since I got here on Wednesday my phone won’t let me make out going calls!!! And I need my phone to make calls back to the UK! It’s like it’s barred!?? Also I have eu roaming turn on in my phone settings and it still isn’t working. Help please!!!!!
Jodie
Highlighted
by Ace Contributor
Hi @Jodietodd26  Have you tried following the advice given earlier in this thread? Let us know what you've tried and we can see if we can assist.
Recent solutions
