by vic154 Investigator
Roaming not working
Hi
My data is not working in France, try to ring the 150 number and its says calls are bared.
Though when log in online say the data back is activated?
11 REPLIES 11
by Ace Contributor
Re: Roaming not working
In order to call and use data whilst abroad, please could you check the following options are set to allowed on MyEE?
- Use Data
- Roaming Abroad
- Call Abroad and Premium Number
W
Hi winston
can i do this on the app or on the website and where?
Hi @vic154
You can find these options under Menu - Manage your device on the EE website log in. You might have some problem activating these at the moment as EE are undertaking system maintenance.
Hi
so the option are still not appearing and i am unable to phone ee as all calls are bared and the text message are failing to send.
Hi @vic154
Welcome to the community.
Are you on pay as you go or pay monthly?
Also, can you receive calls and texts?
Leanne 🙂
Pay as you go, i have received messages from EE
though when another EE mobile rings it goes straight to voicemail and doesn’t dial through
Hi @vic154
Thanks for coming back to me.
Did you use the SIM card in the UK before travelling to France?
The SIM card would need to be activated in the UK first for this to be used abroad.
Speak soon.
Leanne 🙂
Yes i used it to ring another EE mobile... when in London, am now in Nice and nothing.
Hi @vic154
Can you receive calls and texts?
Or, do you have another UK mobile number that can receive calls?
Leanne 🙂
I have been receiving messages from EE
Thanks for confirming this @vic154
I have sent you a private message for further information.
Speak soon,
Katie 🙂
