by Zonfrillic
New Member
Roaming not working
Help! I am in Italy and the roaming doesn’t work
by Star Contributor
Star Contributor
Re: Roaming not working
Hi @Zonfrillic
have you tried the following?
Using your phone abroad
  1.
    check if your phone is set up to work abroad by texting ROAMING to 150
  2.
    if it is, and you’re abroad within the EU, you’ll connect automatically to 4G (where available) for free
  3.
    to use your phone outside of the EU, turn on data roaming in your device settings
@Zonfrillic: Did you activate roaming on your EE a/c before you left UK?
Try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
@Watkins07 wrote:
 3. to use your phone outside of the EU, turn on data roaming in your device settings
Not quite!
3. to use your phone anywhere abroad & only if you wish to use data, turn on data roaming in your device settings
by Profile closed
Not applicable
Are you in Roam?
Good Morning @Zonfrillic
Welcome to the community 🙂
Have you been able to follow the advice given by @Watkins07 and @XRaySpeX?
Has this now been resolved?
Thanks, Katie
