by Breeb Investigator
Roaming not working in some countries
I purchased a 20 pound 10gb data pack in London, however I didnt get the chance to activate it until I arrived in munich. I was able to receive all the texts welcoming me to ee, however data didn't work and I couldn't send texts or calls. When I then travelled to Croatia a couple days later everything worked fine, however not that I'm in Prague for some reason it's stopped working again.
I've tried selecting a network provider manually, along with restarting many times however nothing works. Additionally I attempted to go to manage devices on my account to enable roaming, however there is no tick box there to enable roaming - it just has a link saying find out more. Any assistance would be appreciated.
9 REPLIES 9
by Star Contributor
Star Contributor
Re: Roaming not working in some countries
Hi @Breeb
did you text “ROAMING” to 150 when you set off on your travels?
Have you enabled data roaming in your device in the settings?
are you able to check how much data you have left from your pack at all? Could you have perhaps used it up?
Roaming is auto activated for PAYG SIMs. There is no need to text ROAMING. Hence you don;t see anything about roaming in MyEE.
by Brilliant Contributor
@Breeb , if you did not activate or use your SIM card before leaving the UK, then this may be the reason why it will not work, as SIM cards have to first be activated in the UK and used once in the UK before it will work in another country, as there should otherwise be no problem in Europe, and it should work in Germany.
Have you also checked here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Help-when-abroad-with-your-EE-phone-or-device/td-p/...
Hi @Breeb
Welcome to the community.
It's unusual that the SIM has worked in Croatia but not in Germany or Czech Republic.
@Schockwave is correct though. If the SIM isn't activated in the UK before travelling abroad, it can cause problems with functionality.
When you go to the add-on status page, what does it say?
My mistake, had not realised that it had worked in. Croatia, it should work in Germany then, need to make sure that you have enough on your sim financially for it to work.
When I go to the addon status page it just won't load, so can't see anything. I've done all the other steps in every guide, slightly frustrating as I was assured I could activate overseas and it would work.
Hi @Breeb,
Were you actually able to use your SIM in Croatia?
Did you successfully make a call or send a text?
I didn't actually make a call or text as I didn't need to - data worked perfectly for the whole week though.
Hi @Breeb,
To get this looked into, please get in touch with Customer Care.
Please be aware that if the SIM has never been used in the UK, they may not be able to lift the roaming restrictions until you return to the UK.
