by AnujVarma
Roaming not working in Switzerland
Roaming doesn't work in Switzerland using EE even though roaming services are enabled on my subscription. Please help.
Re: Roaming not working in Switzerland
@AnujVarma    Do you have a signal showing on the device? If you do have you enabled within your EE account call abroad and premium rate numbers ?
by AnujVarma
Unfortunately it is not registering with any of the local network providers. I have a corporate mobile connection so I assume it cannot be any credit issue.
Get Outlook for iOS
Hi there @AnujVarma
Welcome to the community.
Have you tried connecting to a different network on your phone as below;
  • iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Does this work for you?
Leanne 🙂
Recent solutions
