by AndyConnell61 Investigator
Roaming not on
My phone isnt recognised while im in spain, neither is the wifes, haad no probs in Feburary but now ive no service and phone not recognised
6 REPLIES 6
EE Employee
Re: Roaming not on
Hi and welcome to the community @AndyConnell61
So I can try and help, please may I get you to perform a manual network search and choose a network that is available.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Re: Roaming not on
Thanks for replying, done all that, cant ring anyone as ive no network and devuce is showing as unregustered on network, wifes is tge same, roamings always worked except now, £90 a month for this garbage
EE Employee
Re: Roaming not on
Hi @AndyConnell61
Thanks for trying this for us.
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
Re: Roaming not on
Lee i think its sorted, ive gone through your steps again and i think its done, Thank you very very much Lee
EE Employee
Re: Roaming not on
Brilliant @AndyConnell61
Enjoy your time in Spain 🙂
Cheers
Lee
Re: Roaming not on
Thanks Lee😎
Sent from my Samsung Galaxy smartphone.
Recent solutions
