by Moonoxo Investigator
Roaming not active been more than 24hours
I've been in turkey for 24hours and my roaming data calls and texts are still not working 😞 helpp
by Ace Contributor
Re: Roaming not active been more than 24hours
Hello,
Please click on Manage your device  to check if your roaming enable on your account.
If your Roaming enabled.
Then try to search network manually select a network and turn your phone off and on.
It might work for you .
If you still have problem then you need to Get in Touch with EE.
you can do this by calling or via live chat if you are a pay monthly customer by pressing +EE.
I hope it will help you.
Many Thanks
It isn't letting me enable my roaming I am on the maxi plan so not sure why it won't allow me to do it through manage my devices. And I have tried searching manually still nothing. Can't find option for live chat can you send me a link please! 😞
It isn't letting me enable my roaming I am on the maxi plan so not sure why it won't allow me to do it through manage my devices. And I have tried searching manually still nothing. Can't find option for live chat can you send me a link please!!
by Ace Contributor
If you have decent wifi, use Skype and call EE free, on +44 800 956 6000
Hi @Moonoxo,
Welcome to the EE Community.
I've sent you a private message with a link to chat with customer services online.
Hope this helps.
