Highlighted
Roaming issues
Hi
I recently upgraded my phone to S10 and currently having issues sending texts and calling from abroad. Roaming is on. What should I do?
Highlighted
Re: Roaming issues
Hi @downunder400
Have you checked roaming and international calls to ensure they are active? They are normally reset if you upgrade.
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Recent solutions
