by MrReni
Roaming in italy
My roaming in Italy isn't workijg as expected.
According to the help site it should just work.
Data seems to work and I have turned on data roaming.
I'm coming calls seem to work.
I cannot make calls or send texts.
I seem to be roaming on Tim network mostly.
Pls help...
Re: Roaming in italy
Hello there @MrReni
Can you try and connect to a different network as below;
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Can you try and make a call again, does this work for you?
