Highlighted
Roaming in canada
Is my data plan able to be used abroad in Canada or will I have to pay for roaming?
4GEE Max plan 60gb £48
Highlighted
by Ace Contributor
Re: Roaming in canada
Hi @Weemissii As long as you're on a max plan from after 10th May 2017, then yes, Canada is included and you can use your data plan whilst in Canada.
Check you have roaming enabled if you've not used it before (text ROAMING to 150 to check.)
Have a great time there!
Highlighted
Good Morning @Weemissii.
Welcome to the community 🙂
That's great advice from @chistery!
You can see a full list of costs in Canada on our Roaming costs page.
The column on the right hand side shows you everything included in a max plan.
I hope you enjoy Canada!
Jon
