Highlighted
by Investigator
Roaming in USA
Hi can I use a Roam Further add-on on a sim only 4GEE plan? I've logged into my account and tried to turn on International Roaming but it says it could not be activated. My phone has Roaming switched on. Do I need to buy the add-on first, then go to my account?
Highlighted
Solution
Re: Roaming in USA
Yes, if it's a 12-month SIM-Only phone Plan.
Remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
Highlighted
Solution
Re: Roaming in USA
Highlighted
by Investigator
Re: Roaming in USA
Thanks XRaySpeX .
Yes, I text 150 and the reply said Roam Anywhere was on. That's what confused me when I logged on to my account and saw the International Roaming tab was off.
Highlighted
Re: Roaming in USA
Good Morning @Moocher2
Since your last post have you been able to activate Roaming through your My EE?
Speak soon,
Katie 🙂
Highlighted
by Investigator
Re: Roaming in USA
Hi Katie Yes thanks, I bought the Roam Further add-on from my account and I've had a text message saying it's active. Although on my account page it still says International Roaming is off, I rang 150 and was assured roaming is active and the add-on is working. We'll find out when I reach the States 🙂
Recent solutions
