by berlinstu
Roaming in Medellin Colombia still not working
l see from the many previous posts that this is not a new topic and many others have experienced this issue.
EE, Medellin is the second largest city in Colombia and your partner, Movistar, provides a great service on local sims. You clearly have a technical problem with your partner, and have not resolved it for a long while (posts about this go waaay back).
REALLY? Please get it sorted, this is mad that there is no roaming in the middle of a city with over 3 million inhabitants.
Re: Roaming in Medellin Colombia still not working
Hello there @berlinstu
Welcome to the EE Community.
I'm sorry to hear you are having problems getting connected in Colombia.
Unfortunately, we are unable to guarantee the coverage or performance of roaming networks.
Our technical support team will do all they can to help you get connected if you get in touch.
Thanks, Leanne.
