by shimmer
Roaming in Maldives on pay as you go
Hello
Ok so I used to have a monthy payment plan till Jan 2018. Then I had roaming off on my phone. However there was a period where I had it on and travelled to Maldives and romaing worked cos I received calls and texts from UK. I never used roaming data then though.
Anyhow in Jan 2018 because I was travelling to Maldives for 7 months I had turned my monthly plan to a pay as you go because I did not want to keep on paying monthly bills for a phone I wasn't using. All I wanted was for it to be active to simply recieve any texts from UK.
However when I did this i forgot I had my roaming off so now that I am in Maldives though my number is a pay as you go ( technically) roaming is not working.
How can I get it to work please?
Tx!
by shimmer
Re: Roaming in Maldives on pay as you go
Hello
Thank you for the quick reply
You said: If your a PAYG customer roaming is enable and you don’t need to
have it enable. In my case it is not. I believe it was because it used to
be a monthly contract one where I had turned off roaming. It is the same
number that I had now turned into a PAYG.
You said: Have you reserved the device since you got there ? What do you
mean by this? The device was bought from Maldives 2 years ago, I took it to
UK and it worked fine
You said: You will need credit on your account to make calls/texts and use
data as your pack allowance will not work while your there. My current
credit is as 2 pounds and I have not added more credit because previously
when it had it roaming wasn't still working.
I don't need to use data roaming. I simply want the number to be on roaming
so I can *receive texts sent this number*. That is the only reason why I
want this number to be working.
Thank you again for your reply
S
@shimmer  If your a PAYG customer roaming is enable and you don’t need to have it enable.  Have you turned the device off/on since you got there ?
 You will need credit on your account to make calls/texts and use data as your pack allowance will not work while your there.
EE Employee
Hi and welcome to the community @shimmer
Have you tried turning your 4G connectivity down to 3G at all to see if this helps?
Many thanks,
Lee
