by WAGAMAMA
Roaming in Germany
I tried to use 4GEE Wifi in Germany. It shows "Connect to o2-de" but no practical internet connection.
I'm using PAY AS YOU GO. Please let me know the solution.
by WAGAMAMA
Solution
Re: Roaming in Germany
Hello Chris,
Thank you very much for your contact.
I'm using Osprey 2 mini.
In the meantime, I was able to connect the network.
I assume the solution was to text to 150 and "RO".
Which EE MBB router do you have?
Hi @WAGAMAMA
Welcome to the community, I hope you're having a brilliant time in Germany. 🙂
If you could get back to us telling us which router you have, we'll do our best to help.
by WAGAMAMA
Solution
Hello Chris,
That's just for finding out the costs of roaming. If you're thinking it enables roaming for you, it doesn't but PAYG SIMs are already enabled for roaming. So you don't need to text anything.
Can you now connect to the Internet?
Glad it seems to be working, @WAGAMAMA 🙂
Give us a shout if you need any more help.
Enjoy the rest of your time in Germany. 🙂
