by kat__tu
Roaming in Germany
I am roaming in Germany from the UK. Why is the data so bad? I can receive imessages but I can't use Whatsapp. Everything is slow. I have turned on data roaming. Anyone have a solution?
EE Employee
Re: Roaming in Germany
Hi @kat__tu and welcome to the community.
This does sound very strange, have you tried performing a manual network search and choosing a different network to what you currently are using?
Many thanks,
Lee
by kat__tu
Thanks so much Lee. Actually I realised it's my VPN which got in the way. Sorry for the trouble and thanks again for your help.
Hello there @kat__tu.
Glad you got this sorted, it is never any trouble 🙂
Have a great time!
