by Twoplus Investigator
Roaming in Canada
Hello All,
Can I use my 1000 international minutes to call any of the inclusive countries free while roaming in Canada on a 4GEE SIM Max?
Thanks.
Solution
Re: Roaming in Canada
Yes, if you got this plan after 10 May 2017.
Remember to text ROAMING to 150 before you leave to check you have roaming enabled on your a/c.
7 REPLIES 7
Using international minutes add on while Roaming in Canada
Hello All,
Thanks.
Solution
@XRaySpeX Thank you.
Hi @Twoplus.
I see you've had brilliant advice from @XRaySpeX.
I hope you have a great time in Canada 🙂
Come back to the community any time.
Jon
Thanks! You're welcome :)! Glad I could be of assistance.
by Ace Contributor
Just to make sure, this is the 1000 International Minute add-on, to allow calls from the UK to 50 countries, and if you have a max plan, those minutes can also be used in the max plan countries? The T&Cs don't mention that?
If you're on a new MAX plan you can use your inclusive minutes to call the UK, EU and other MAX plan countries though.
@chistery: You're right. International mins add-ons are only for calling abroad from UK.
However, as you say, OP may use his Max Plan inclusive mins while roaming in Canada.
