by gibson7718
Roaming in Canada
Does the 20GB SIM Only plan include calls, text and data usage in Canada?
6 REPLIES 6
by Ace Contributor
Re: Roaming in Canada
Hi @gibson7718 Unless it's a MAX plan, then no. You can check out the add-ons for Canada here
Let us know ifyou have any questions. Enjoy Canada!
by gibson7718
How do I know if it is a MAX Plan?
by Ace Contributor
If you log into MyEE it will tell you under your plan summary.
E.g. You get our very best with your 4GEE Max SIM Plan: unlimited calls, text and 30GB of our fastest speed data to use in the UK, EU and ten other countries. You also get live sporting action on your phone with the BT Sport app.
@chistery: Why 10 other countries? Surely only 5?
I.e.:
Plus, our 4GEE Max plan lets you talk, text, browse and share in even more places – an incredible 53 countries. As well as using your allowances within the EU, you can use them in Australia, New Zealand, Canada, Mexico and the USA.
53 = 48 EU + 5 outside.
by Ace Contributor
I.e.:
It's the EEA + Switzerland + 5 Max plan countries or something like that.
Hi and welcome to the community, @gibson7718. 🙂
Did you manage to check that your plan gives you 53 countries through your My EE account?
Recent solutions
