by peter753
New Member
Roaming in Australia
Will my smart phone work with my UK SIM card and plan in Australia?
by Ace Contributor
Solution
Re: Roaming in Australia
Please follow the instructions under the section “Do I need to set up my device to use abroad?” in the link below:
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/austra...
W
by Ace Contributor
Solution
W
