by Skilled Contributor
Skilled Contributor
Roaming - deposit required?
I've been reading the forums and came across by someone who went abroad and found he/she had to pay a deposit for roaming to work, and about which he/she was completely unaware.
Is it all new customers who have to pay a deposit? And if one does need to pay, where is that information communicated?
I am a new customer, roaming is activated on my online EE account - will I need to pay a deposit to roam in the EU or elsewhere?
Solution
Re: Roaming - deposit required?
You'll be OK if texting ROAMING says it's enabled.
7 REPLIES 7
It will depend on your credit history/rating - see Security deposits and credit checks from EE . You should still be asked or told of it.
Skilled Contributor
Thanks @XRaySpeX, so basically my roaming should work as expected seeing as I have got no notification of any deposit required.
For customers who *are* required to pay a deposit, how is this communicated to them?
It depends on how your purchased the contract as if in store it should be on your paperwork and explained to you at the time of sake. Equally if purchased online it would be detailed in the purchasing process (small/legal print).
To check roaming is activated txt ROAMING to 150
Skilled Contributor
Thanks @Northerner, I bought online and didn't see anything anywhere about a roaming deposit. Roaming is enabled on the EE online account and I texted as you suggested, getting a reply back that it's all set up.
So from what you say, if EE required a deposit from a customer before they could use roaming, then either roaming would not show as enabled on the EE online account or they would get a text mentioning the deposit requirement... as long as roaming shows as activated, then there is no deposit requirement. Correct?
Just to check, you are not on PAYG, are you? Roaming is auto enabled on PAYG as you can't exceed your own credit.
Skilled Contributor
No, I'm on Pay Monthly, new customer since about 10 days ago.
The only reason I want to clarify this is another post I read where someone thought roaming was on, then went abroad and found out EE required a deposit, so I want to make sure this doesn't happen to me.
Solution
