by DawnB1 Investigator
Roaming charges
My current roaming charges are less than my normal monthly plan, I'm on a very old plan which suits my needs. Will I be paying more when using my phone in Spain after 15 June?
6 REPLIES 6
by Ace Contributor
Re: Roaming charges
@DawnB1
After 15,June you can use your phone same as UK in when you traveling Europe.
There is no extra cost using your UK allowance in Spain after 15 June.
Please click here  EU roaming  for more details.
Many Thanks
Re: Roaming charges
So I will be paying more to use my phone while abroad than what I currently pay when roaming?
Re: Roaming charges
How can that be?
  1. Before 15 June you were paying normal monthly plan + roaming charges (even if < normal monthly plan).
  2. After 15 June you will be paying normal monthly plan + £0 for roaming in EU.
by Ace Contributor
Re: Roaming charges
@DawnB1
For example if you have package plan that gives you 500 minutes, unlimited text, and 2gb data and you pay for this 25 a month  after 15 June you can use all your allowance in Europe same as 25 a month if you don't go over your allowance.
Many Thanks
Re: Roaming charges
I'm on a very old Orange EQ Virgin tariff, I think call charges were 15p per minute and texts 5p while in the UK. I only pay for what I use monthly by direct debit. I use the phone in Spain and only pay 0.015p per text and about 3p per minute for calls. I spend more time in Spain than in the UK so have never wanted to change the plan due to the savings.
EE Employee
Re: Roaming charges
Good Morning @DawnB1
As far as I'm aware the charges will revert to the standard UK charges.
I will get this double checked for you though.
I'll be in touch soon.
Thanks - Karen. Smiley Happy
