by PT21 Investigator
Roaming charges on a Max plan
I'm heading to Barcelona. What are the charges to use my call and data allowance on a Max plan?
by Ace Contributor
Solution
Re: Roaming charges on a Max plan
HI,
@PT21
You can use your unlimited  call / text allowance and up to 15 gb data in Barcelona with out any extra cost.
Take a look at EE roaming guide
There is no charge, but please text ROAMING to 150 to ensure roaming is activated on your account.
Thanks,
by Ace Contributor
Solution
HI,
@PT21
Hi @PT21,
Welcome to the EE Community. Smiley Happy
Did @Northerner and @tahirmian's great posts give you all the information you needed?
