by Anna1990
Roaming charges italy
Going to Italy on holiday in a week time. Can I leave my data switched on? Thanks
Anna
by Ace Contributor
Solution
Re: Roaming charges italy
HI,
@Anna1990
Yes you can and it's free to use data allowance Italy.
But make sure your roaming on before you travel you can do this texting Roaming to 150.
And also suggest you you to call customer service on 150 from ee or any other provider to 07953 966 250 to make sure no international call barring on your account.
by Ace Contributor
Solution
HI,
@Anna1990
Text ROAMING to 150 and you will receive a message confirming your roaming status. If set up then you need to do nothing. If not you need to call CS on 150.
Please also see EE roaming guide here
Enjoy your holiday.
Hi @Anna1990
Thanks for coming to the community to see us 🙂
I hope the thorough and fantastic information given to you by @tahirmian and @Northerner has given you the help you needed.
Cheers
Richard
