by Ajwebster
New Member
Roaming charges in Greece. Are there any?
Re: Roaming charges in Greece. Are there any?
Hi there @Ajwebster
Thanks for coming here.
You can use your minutes, texts and up to 15GB of data within Greece.
If you're in Greece or Cyprus, your device may automatically connect to a Turkish network. As Turkey is not within the EU, you may be charged for making calls, sending texts or using data while connected to a Turkish network.
To make sure you're not charged, check you're on the right operator in your device settings.
If you have a pay monthly account, I would recommend making sure roaming is active on your account by texting ROAMING to 150
Thanks.
Leanne 🙂
