by Pamrob28
New Member
Roaming charges in China
I have accidentally left roaming on my phone whilst I am in China and I'm worried I have incurred charges outside of my plan ? How can I check ?
by Brilliant Contributor
Re: Roaming charges in China
Hello @Pamrob28,
Welcome to the community,
Are you able to log-into your account and check there? Although it may not show up, as roaming charges take longer to show up.
If you have not paid for roaming data, then you should not be charged anyway, as you need credit to be able to use it.
This might help:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/how-roaming-data-add-ons-work
I would also add to @Schockwave helpful comments that it may not show on your bill for 30+ days depending on the billing system in place with the foreign network.
Thanks,
