by simonhadfield11 Investigator
Roaming calls barred
Hello, I'm currently roaming in Denmark ( from the UK ), and I haven't been able to make calls or send messages. I have used a payphone to verify that my account is set up for roaming. On the settings of my phone app I can see that international outgoing calls are barred, and a password is required to change this setting. I have not set up any password. Could anybody help me to find this password or otherwise enable calls and messages?
I am using a Samsung Galaxy A5 on a monthly contract. It has android 6.0.1 installed.
Thanks, Simon
EE Employee
Re: Roaming calls barred
Hi @simonhadfield11 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447*********, did this work?
Also, please let me know If you are using an EE personal or business account as I may be able to assist with our live chat service?
Many thanks,
Lee
Hi Lee,
Thanks for your response. I have tried your suggestion and have the same result when using a different network. A message comes up on my phone saying 'outgoing calls barred'. I should add that incoming calls from the UK and mobile internet are both working fine. Any further suggestions?
Cheers,
Simon
EE Employee
Hi @simonhadfield11
It sounds like your international bar is still active.
Are you a personal EE customer?
Thanks - Karen. Smiley Happy
Yes, I am an EE personal customer.
Cheers,
Simon
Hi @simonhadfield11
I have sent you a private message here to try and help you further.
Cheers
Richard
