by Joysp30
New Member
Roaming 4gee Max Plan
Why do you only get half your data while roaming
Re: Roaming 4gee Max Plan
Do you want to provide a bit more information? What do you mean?
by Ace Contributor
On the 30GB plan, there's a 15GB FUP, so I assume that's what the OP is talking about.
Have to say, for once I'm with EE on this. EE still need to pay for the data you use, and 15GB is still a lot of data. People are already trying to work out the maximum they can use it abroad which suggests they are trying to abuse it already. It was meant for people to use on holiday or for work, not for a long term solution.
