by ClaireW42
New Member
Roam further. How does it work and how far does it cover?
Hi
mum going to Tunisia on Friday and concerned about huge roaming charges. Has anyone used the roam further add on? Will it work in Africa? Does it let you use your minutes, texts, data?
cheers
Re: Roam further. How does it work and how far does it cover?
@ClaireW42   The roaming further add on is only for these locations
USA,Canada,Mexico, Australia,
New Zealand.
if you text RO TUNISIA to 150 you’ll see what options there is for this location.
Hi @ClaireW42.
Thanks for coming to the community 🙂
As @Chris_B has mentioned, the Roam Further Add-on isn't available in Tunisia.
Have a look at our Roaming Page for all of the bundles available and the costs without a bundle.
Jon
