by garyspacey1
New Member
Ringing uk from Spain on travel max plan
I’m currently in Spain, I have the travel max plan but I cannot ring uk numbers I’m currently in hospital and need to liase with insurance. can i active the ability whilst abroad?
by Brilliant Contributor
Re: Ringing uk from Spain on travel max plan
Hello @garyspacey1 ,
Welcome to the community,
Sorry you have ended up in hospital while in Spain, but have you taken a look here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Help-when-abroad-with-your-EE-phone-or-device/td-p/...
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do the above.
Hi @garyspacey1
Welcome to the community. Sorry to hear that you're in the hospital, I hope everything's OK.
Are you able to receive calls, send text messages etc?
Once you've followed all of the steps above, it should help you connect. If you're still having problems, please try a manual network search and choose another available network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Look forward to hearing from you.
