by Danir14
Restricted calls abroad
I can’t ring from polland it’s saying my calls are restricted but roaming is on
Re: Restricted calls abroad
@Danir14   if you have a signal on the device you need to login to your online EE account and enable call abroad and premium rate numbers then restart the device.
by Danir14
I have done this and it still does not work
Sent from my iPhone
Hi @Danir14.
Once you've enabled premium rate calls, it can sometimes take up to 24 hours for it to fully activate.
Have you tried restarting the phone?
Jon
