by Travelers
Restarting sim and changing pack
I am after cheap calls to Australia, but mostly am after the maximum data amount to use in Britain.  The International Pack to make the calls only seems to have a small amount of data attached (I am looking at 20 gb if possible).  Do I add two together to get what I am after?
I was previously in the UK with the lower international pack and have since cancelled it.  I need to restart this phone number using the same sim but with a new pack. I also would like to know if my boosts, unused data and credit from the previous pack will be usable for the new one?
Thank you
by Travelers
Re: Restarting sim and changing pack
Hi - it was last used in January this year.
1st things 1st ...
When did you last use this SIM for any chargeable action? EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
No, you can't add packs together. You may only have 1 running at once.
Assuming your SIM is still live (see above) ...
Your best bet for 20GB is the £30 30-day Everything Pack with 20GB data, 3000 UK & EU mins and unlimited UK & EU texts. To buy it text EP30 to 150. Your boosts & credit will remain. You won't have any unused data left from previously. For a full list of packs you may buy see What are pay as you go packs?
Of course these packs don't include calling a non-UK no. from the UK. You are not roaming when you do so. They count as International calls & are chargeable.
International calls & texts to overseas nos. from UK can be rather expensive but EE has a free add-on that anyone, on PAYG or contract, can apply for to give these calls & texts at a fraction of the standard rates. See The Free CALL ABROAD Add-on for Cheap Calls/Texts from UK . Unlike the International Packs you will be paying for calls to Oz but at a cheap rate (3p landlines, 10p mobiles) / min but you are getting the bigger data.
Then you should be good for buying another pack when you get to UK.
