Highlighted
Reset carrier EE not working good
I’m in Italy EE reception not good how do I search for other
Highlighted
Solution
Re: Reset carrier EE not working good
Hi @Carima
EE are not responsible for foreign networks.
Try going into your phone network settings, disabling auto select and then selecting another network.
Highlighted
Solution
Hi @Carima
Highlighted
Thanks so much I’ll give that a try.
Cheers
Recent solutions
