by Moon75
New Member
Remove call bar
Need international call bar removed
by Ace Contributor
Re: Remove call bar
@Moon75
You need to call customer services on 150 from EE or from other provider 07953 966 250 to remove your call bar.
Or
You can do this via live chat as well opening Get in Touch page Underneath +EE.
Many Thanks
EE Employee
Re: Remove call bar
Hi @Moon75 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447*********, did this work?
Also, please let me know If you are using an EE personal or business account?
Many thanks,
Lee
