by Mr_Musta Investigator
Re: call barring germany please help!
I am currently having the same issue. Will someone be able to help?
kind regards,
mustapha
EE Employee
Hi @Mr_Musta and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Hi Lee,
i tried both options and I was able to make a call to my friend. But I cannot call other numbers such as numbers that start with 0207
thanks
EE Employee
Hi @Mr_Musta,
This is very strange, have double checked the numbers you have dialled are correct?
Many thanks,
Lee
Hi Lee,
ive checked the number and tried calling different numbers but the call fails. I also cannot call 150 for customer service
kind regards,
mustapha
EE Employee
Hi @Mr_Musta
Thanks for trying this for us.
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
Recent solutions
