by Slart1bartfast Investigator
Re: WIFI Calling & Signal Box
Your data roaming doesn't work in Vietnam and I'm locked out of my ee account, you have seriously let me down and affected the cost and my enjoyment of my time away.
12 REPLIES 12
Re: Manage family on app
Hello there @Slart1bartfast
I am sorry to hear this.
Are you able to make and receive calls?
Are you with us on pay as you go or pay monthly?
Thanks, Leanne.
Data Roaming doesn't work in Vietnam
@Slart1bartfast: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Re: Data Roaming doesn't work in Vietnam
When I try to log in to my ee it says they are carrying out maintenance on my account please try later, it's said that for the past three days. I usually use giffgaff but had to order a new giffgaff sim for my new phone so went with ee just to see what they were like.they are dreadful, twice as expensive as giffgaff on calls and texts from Vietnam. I can't top up as I can't log in.ee have screwed me in this trip, never again.and as for the purchase of a roaming pack not enabling it what a crazy piece of design,I paid for a pack that I couldn't use because I didn't enable its use before I left.wtf.
Are you trying top up so you can use data?
If so and your unable to access My EE please call us on +44 7953 966 250.
Our pay as you go team will help you with this.
Thanks, Leanne.
Pay as you go.I've burnt through £30 of credit plus a £10 token that came with the phone in texts and calls to 150! I calling my mother who has dementia and was cut off after a couple of minutes because I'd used my credit to try to sort data roaming and get access to my ee login to buy more credit!
As you are on PAYG you do not need to activate roaming; it is already activated on PAYG.
Call 360 to top-up.
You can't use PAYG packs in Vietnam. They are only valid for EU & UK. You will need to pay standard roaming rates for call & texts and buy add-ons for data. For prices see http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/vietnam .
Dialed 360 then +44360, got number does not exist.already been to that url and brought £5 o r£10 worth of data that lasts 24 hours.it didn't work. Ee has turned into a kafka-est catch 22 (to mix metaphors), I can't top up without logging into my ee I can't log into my ee as my account is being updated and any way the data roaming doesn't work.congratulations on such an awesome product.
EE Employee
Hi @Slart1bartfast
This is very unusual as 360 should allow you to top up whilst roaming.
Many thanks,
Lee
Without prefix or suffix?
Yes.
Hi @Slart1bartfast
How did you get on? Did you manage to get through?
Could you try doing a manual network search and trying a different available network?:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know how you get on.
