by Marcosigm Investigator
Re: Roaming
I have the same problem. Although yesterday I had roaming from orange. And now it can’t connect to any mobile company.
Re: Roaming
Hi @Marcosigm.
Welcome to the community.
Are you able to perform a manual network search to see if you can reconnect to Orange?
What to do if you're having problems abroad >
Jon
