by frandom Investigator
Re: Outgoing International Roaming - Barring Enabled
Im on PAYG and currently roaming but unable to call or text, please can you send me a chat link to resolve this?
thanks
8 REPLIES 8
Hi @frandom,
Welcome to the EE Community.
Our chat teams only have access to pay monthly accounts.
Pay as you go accounts are automatically set up to use abroad.
Have you tried selecting a network manually?
Do you have sufficient credit to make a call?
I have plenty of credit and have tried several networks but same problem on all of them.
thanks
Hi @frandom,
Where are you roaming?
What happens when you try to make a call?
Can you use data?
@frandom  You are putting 44 or 0044 instead of the 0 at the start of the number?
It tells me 'can't make outgoing calls while call barring is on', but I can't change the barring setting from my phone.  Texts just say failed to send and i dont think data is working either.
I am using the correct dialling code.
thanks
EE Employee
Hi @frandom
Which country is it that you are currently roaming in?
Many thanks,
Lee
Hi
I managed to speak to customer service who were able to resolve the issue.
thanks
EE Employee
