by Gerald1
Re: CAN'T USE MY PHONE ABROAD!! PLEASE HELP!!
I cant use my Phone before i moved abroad i turned it to pay as you go i had top it up you keep the money and the number still innactivate. I try to connect with you i had Sent you many messages without answer!! Im very disappoited
Hello there @Gerald1
Welcome to the community.
When was the last time you used the phone to make a call, send a text or use the internet?
Also, when did you last top up?
Speak soon, Leanne.
@Gerald1  Sent many messages !  how ?
 And when you change it to PAYG your on packs that last a month unless you text STOP PACK and then it’s a normal payg and credits go towards calls and text and last until used up.
by Gerald1
Last time that i send text was in March 2018 since then i was abroad and the last top up was 20 days ago from my friend there. I cant undestand why im  embarrassing while at the  store told me that i will not have any problem.. and the fact that when you are abroad you cant communicate with the ee company. Its not easy to call from abroad. I will apriciate any help. Thank you in advance
Hi @Gerald1
Have you tried manually connecting to a network out there?
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Please let us know if any networks come up.
