by Matt999 Contributor
Problems with roaming Brazil. Orange payg.
 I am on Orange payg using a moto g 1. When roaming in Europe,  it all works well but in Brazil none of the networks can connect to the phone
11 REPLIES 11
EE Employee
Re: Problems with roaming Brazil. Orange payg.
Hi @Matt999 and welcome to the Community.
This is very strange, when you manual network search do you see any other networks?
The list below are networks that are active in brazil please bare in mind we may only roam on a select few.
1: VivoGSM
2: TIMGSM
3: ClaroGSM
4: OiGSM
5: Nextel
6: Algar Telecom
7: Sercomtel
Are you able to try another handset with your SIM card in?
Many thanks,
Lee
Yes, I can see all the different networks but when I try to connect them, I get the message that the service is unavailable.
Unfortunately I don't have another phone to see where the problem lies
Hi @Matt999,
Have you had any luck connecting to a network yet?
It could be a local network issue if you are still having problems.
Still not solved.  I can see the name of the operator, including an r next to the recpetion bar, which is full.  But  when I try to use the phone to call or text it disconnect.
EE Employee
Morning @Matt999
Sorry to hear it's still not working for you!
Do you know if you can receive calls OK?
Thanks - Karen. Smiley Happy
Hi, no can not receive calls either.
I have given up, can't figure out what it could be.
EE Employee
Hello @Matt999
The next step would be to give Customer Services a call and speak to the technical department.
I know this may be expensive from Brazil.
Really sorry we couldn't help further on community.
Strangely enough today I received a text. So I guess something works. I don't quite understand.
Would you be able to help.
Strangely enough, today I received a text, something is working, totally confused now.
Anyone has an any idea
EE Employee
Good Morning @Matt999
You would need to call customer services for further support.
It could be an issue with the network out there, I would keep trying manual network selections.
