by MBD
Planning to travel to New Zeland, What will be the best way to keep connected?
Solution
Re: Planning to travel to New Zeland, What will be the best way to keep connecte
Otherwise, you can see the charges in https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/new-ze... .
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
@MBD   What type of type of plan do you have ?   If you’ve got a max plan you can use your allowance while there.
Solution
Recent solutions
