by hma2503
Phone not working abroad
Phone can receice calls and texts however will not send. 3G does also not work unless roaming is on. Contract says that it should work and I essential got the plan for being able to use the data.
6 REPLIES 6
Re: Phone not working abroad
@hma2503    Did you call customer services and request that roaming be enabled in your account or did you text ROAMING to 150 before you left the UK.
And if you have a toggle on the device that turns roaming on then it needs to be on for it to work.
EE Employee
Good Afternoon @hma2503
Welcome to the Community! Smiley Happy
It sounds like your international bar may still be active.
Are you a personal EE customer?
Your Data Roaming will need to be turned on so you can use data abroad.
Thanks - Karen. Smiley Happy
by hma2503
Yes I have an EE contract. Will I be charged extra if my Data Roaming is turned on? A EE shop assistant explained not to turn on this and leave my phone setting as they are.
@hma2503  With it on you will only use what in your alliance.
by Ace Contributor
@hma2503
Data Roaming will need to be turned on if you want to use Data abroad.
To remove international calls barring open this page http://ee.co.uk/help/get-in-touch
And click on +EE to find live chat option with customer adviser to remove call barring.
Many Thanks
EE Employee
Hi @hma2503,
So I can try and assist, please may I know which country you are currently in?
Many thanks,
Lee
