by Corky468
Phone is restricted whilst in Spain even though roaming is enabled. Help?
My Apple iPhone 6s is roaming enabled and my Ee account says it is too. However I can’t make calls as it says they are restricted. I’ve seen similar questions on here but can’t find a web chat link anywhere to sort it. Any help out there please.
by Legend
Legend
Re: Phone is restricted whilst in Spain even though roaming is enabled. Help?
Hi @Corky468
Try resetting your network settings.
You can also check if roaming is active on your online account and access chat via this portal. You can also access chat via your EE app.
Thanks,
Hi @Corky468,
Welcome to the EE Community.
If you login to My EE and select Manage device from the menu, is Call abroad and premium rate toggled on?
