by Angie16
New Member
Phone is in germany my texts arr not working but wifi is do i need go asettings
using my phone in germany but texts not working but Wi-Fi  is do i neee ro change anything in my settings
Re: Phone is in germany my texts arr not working but wifi is do i need go asetti
@Angie16: Are calls & data working?
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Hi @Angie16
Welcome to the community. 🙂
Did you manage to get sorted following @XRaySpeX's advice?
Here are some other troubleshooting steps that may help:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search and select a different German operator:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
