by Kerrygipp Investigator
Phone has signal now nothing stuck in spain
Unable to use phone while abroad. Did have roaming now nothing cant even txt
Re: Phone has signal now nothing stuck in spain
@Kerrygipp  have you tried restarting the device? Also log into your online EE account and make sure roaming is enabled and also call abroad and premium rate numbers.
Hi there @Kerrygipp
Thanks for coming here 🙂
Can you try a manual network search within your device settings;
  • iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
  •  Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  •  Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Has this worked for you?
Leanne 🙂
